-   -   How much current starter solenoid line draw? (http://forums.pelicanparts.com/porsche-911-technical-forum/401761-how-much-current-starter-solenoid-line-draw.html)
JoeMag 04-02-2008 10:09 AM
How much current does the starter solenoid line draw? ...or maybe, how big of a fuse should be in that line? wiring race car.
911pcars 04-02-2008 10:39 AM
I installed a remote starter in mine to reduce wear and tear on the NLA ignition switch. Here's some info:
http://members.rennlist.org/911pcars/RemoteStarter.htm
I ended up using a 10A fuse, maybe 15A. YMMV depending on compression ratio, starter motor, your custom electrical system variables, etc. That should get you in the ballpark.
Hope this helps,
Sherwood
JoeMag 04-02-2008 01:57 PM
that works! thx
