Lee
Guest
Posts: n/a
Question 2 bolts to short for cam cover housing?
Hello, I'm going to start my tensioner update tonight, and could use some help on this topic...I seem to remember a post that spoke of two studs which needed to be replaced in order to install the cam housing covers. However, search as I might, I can't find the link.
I'd like to be thoroughly prepared before I start, and I wonder if anyone can tell me if they are familiar with that post, and what are the size of the studs needed.
Thanks so much
Daniel Crockett
'78 SC
Old 05-09-2001, 02:35 PM
Early_S_Man
Guest
Posts: n/a
Lee,
They are 8 mm, so, if you pick up a couple of standard M8 x 40 mm Grade 8.8 bolts that are threaded full-length, you will be ready to make replacement studs.
Warren Hall
1973 911S Targa
Old 05-09-2001, 03:19 PM
