stormin
Guest
Posts: n/a
Post smoke at startup
My 98 Carrera S once in a while will blow smoke out the exhaust at the initial startup in the morning. The car runs smoothly at regular temperature. My dealer shrugs his shoulder and says this is normal. What do you guys think?
Old 05-09-2001, 08:51 PM
Blackdimonds
Guest
Posts: n/a
Post
Did you say 1998 Carrera 2? My 81 does it, as well as most older (64 - 89) 911s I see, but I have yet to see a water cooled Porsche do this. I would be concerned if the car is out of warranty soon.
Paul
81 911SC
Old 05-09-2001, 09:03 PM
Mike Feinstein
Guest
Posts: n/a
Post
98 is air-cooled (993). If your oil is a bit overfull or the car has been sitting a while it's perfectly normal. If it only does it occasionally, don't worry about it.
Mike 94 C2 cab
Old 05-09-2001, 09:19 PM
lucky77
Guest
Posts: n/a
Post
I agree, err...my 77 does this...
Matt
77 911S
Old 05-09-2001, 10:36 PM
ZE911
Guest
Posts: n/a
Post
We're dealing with different cars and engines. The 3.2 in the car I drive smokes on start up now and then. Very rarely. My wrench tells me that the valves can stop in a position that allows oil to enter the cylinders on shutdown. The car has done this twice over the last 3K miles.
Old 05-10-2001, 01:16 AM
rstoll
Guest
Posts: n/a
Post
Mine does this occasionally. Last night's belch must have cleared every mosquitoe in my neighborhood. Most of the time it doesn't smoke at all, but every once in a while it really lets go. Just keep saying to yourself....it's normal, it's normal...yeah, that's it...normal.
Robert Stoll
83 SC
83 944
Old 05-10-2001, 05:02 AM
Jon Green
Guest
Posts: n/a
Smile
As long as your oil consumption is OK then this is fine.
It is a characteristic of the boxer engine.
They all do it to some degree, even the BMW motorcycles.
Regards, Jon
'76 2.7S
Old 05-10-2001, 05:52 AM
stormin
Guest
Posts: n/a
Post
Thanks for the reassurance, guys!
Old 05-10-2001, 06:49 AM
john walker's workshop
Guest
Posts: n/a
Post
nature of the beast. parking at any angle aggrevates the condition, allowing oil to puddle behind the piston, and seep past the rings. it doesn't take a lot of oil to make a lot of smoke.
Old 05-10-2001, 08:06 AM
