BK911
Guest
Posts: n/a
Question oil lines
Does anybody know if the oil line fittings on a 70 are a different size than those on an 84? The reason I ask is because I am trying to retrofit an 84 front mounted oil cooler onto my 70, which does not currently have one. If anybody knows the size for each I would appreciate the info.
Thanks!
BK
Old 05-10-2001, 06:17 AM
john walker's workshop
Guest
Posts: n/a
Post
the threads on the oil cooler and oil tank of a 70 are smaller.
Old 05-10-2001, 08:08 AM
BK911
Guest
Posts: n/a
Post
Thanks for the reply, Mr. Walker. Any idea what the sizes are? 16AN Vs. 12AN?????
Thanks again,
BK
Old 05-10-2001, 10:04 AM
orbmedia
Guest
Posts: n/a
Post
Whoa! Porsche doesn't use AN do they? They're metric.
Old 05-10-2001, 10:37 AM
KTL
Guest
Posts: n/a
Post
BK,
The threads are not AN, they're metric. Something like M22 (on the 84 hardware), but not sure.
Kevin
87 Carrera
Old 05-10-2001, 10:39 AM
BK911
Guest
Posts: n/a
Post
Obviuosly I have no idea what they are! I was going from an after market catalog who had the oil lines in AN fittings. Good thing I didn't order anything from them!
Thanks for the heads up!
BK
Old 05-10-2001, 11:01 AM
911pcars
Guest
Posts: n/a
Post
I believe the oil cooler lines are 32 mm. Some time in the early 70's, the oil tank line went from 30 to 32mm. So if you're installing a late front oil cooler system on an early 911, you'll need an adapter(s) of some sort on both ends.
FWIW, I got AN-to-metric oil cooler adapters (2) from AJ-USA and an oil line-to-oil tank adapter (1) from Otto's.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-10-2001, 12:18 PM
