Guest
Posts: n/a
I love this board. When I am Slowing down just before I come to a complete stop I Here a distinct metal sounding clunk. Any clues? thanks in advance
Guest
Posts: n/a
From which area of the car?
Guest
Posts: n/a
sounds like almost under the gearshift but more forward than rearword. cant pin pont it better than that
Guest
Posts: n/a
old shocks can knock. a brake pad that has up and down play will knock. non rubber mounted sway bars knock. loose tie rod ends knock. check the upper strut mounts and the ball joints and tie rod ends for wear. the torsion bars front and rear can knock on their housings when bushings wear out.
[This message has been edited by john walker's workshop (edited 05-10-2001).] |
