Leaving car in gear while parked?
Been having a debate...
Does doing this cause undue damage or stress to components?
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 04-04-2008, 10:02 AM
Don't know about that. But, when I park, I always park clutch in, e-brake on, then brake off so the car is "against" the E-brake. Only after it settles do I let my foot off the clutch.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 04-04-2008, 10:53 AM
Gearbox internals can be damaged and at a minimum, stressed, if the car's in gear. Otherwise, no problem. I place it in gear as a secondary measure when parked on a hill. Parking brake with the front tire banked against the curb are primary means of keeping it at 0 mph.
Sherwood
Old 04-04-2008, 11:01 AM
I do like Wolfe does...imo, a parked car left in neutral is not safe. Out of habit (been doing it for 30 some years), I always leave her in reverse too.
Old 04-04-2008, 11:10 AM
Sherwood, I assume you mean gearbox internals can be damaged if, say, somebody backs into while unparking or whatever? Certainly there can't be any damage from leaving a car in gear with the parking brake on if there's no external stress. And I'm assuming that nobody's dumb enough to depend 100 percent on parking in gear--i.e. no parking-brake use.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-04-2008, 11:12 AM
wastintime's Avatar
Send a message via AIM to wastintime
I only do it on steep hills, and always ebrake first... I just never do it out of practice after racing/DEs etc...
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 04-04-2008, 11:19 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Yep. Same here - all my cars are manual transmissions and I always pull the e-brake first (before letting off the regular brake), then shut the car off in neutral, put it in gear and then release the clutch (with the engine off and the wheels being held by the e-brake). It's a second level of protection - a tertiary one if on a hill (I cut the wheels into or away from the curb if I'm facing down or up a hill respectively).
Black Cars Matter
Old 04-04-2008, 11:22 AM
Ditto with all those who leave it in gear after secured by e-brake. Never had a problem in over 45 years with the trans, but then the car was never bumped hard by an idiot while parked--my only fear.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-04-2008, 11:31 AM
wastintime's Avatar
I almost painted my 912 Ossi Blue... stuck with Tangerine. If they bumped my car hard enough to hurt the gearbox, they better hope they hurt the gearbox so I can't kill them for the dents or scratches they put in my bumper
-Andy
Old 04-04-2008, 11:37 AM
Not near the stress as the 'stomp and steer' to redline...
83 911SC
70 911T
Old 04-04-2008, 12:34 PM
Thanks Steve,
I left out that part of my answer that should have included damage caused by an outside force bumping into the vehicle.
As for putting the gearbox in reverse, that's the gear with the most gear reduction, so it's more difficult for the car to move. However, if hit from behind and the car moves forward, the engine rotates opposite the normal direction of rotation.
That could conceivably stress the valve train components as well as the aforementioned gearbox internals.
Sherwood
Old 04-04-2008, 02:07 PM
Originally Posted by 911pcars View Post
Thanks Steve,
Sherwood
Just like if it's hit from the front and left in first?
To be totally safe, don't ever park it, or leave it in neutral and use one of those "boot" things...or just keep doing what you're doing and not worry about it.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 04-04-2008, 02:22 PM
rotating the engine in reverse can pop the cam chain off the intermediate shaft sproket.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-04-2008, 02:27 PM
wastintime's Avatar
BOTH FEET IN!!!!
-Andy
Old 04-04-2008, 03:01 PM
3.2 CAB's Avatar
Whenever I park mine in the garage, I always have the parking brake ON, and the transmission in NEUTRAL. My parking brake works great, no more than three clicks when set. I pretty much do the same when out in the public domain, but... If I am parking on the side or a mountain, I will place it in gear, either 1st or reverse, and also set the handbrake, and if there is a curb where I am parking, I will turn the wheels so they will be locked in the position pointing toward the curb. Just my $0.03
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-04-2008, 03:44 PM
dshepp806's Avatar
+1.
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-05-2008, 01:04 AM
flatsixnut's Avatar
I use the E-brake only with the car in neutral if I have to park it away from my garage.
When it is in my garage I leave it in neutral with no E-brake. It can not roll out of my garage.
Michael
83 SC Coupe
Old 04-05-2008, 06:29 AM
pozee's Avatar
+1 WolfeMacleod.
The E Brake should "hold" the car. Once it holds, then place in gear. Same with automatics. Better than the transmission gears "holding" the weight.
pozee
Old 04-05-2008, 07:07 AM
Jeff Alton's Avatar
What are you saying here? You DO use your ebrake after comming off the track or you park it in gear with out the ebrake?
Cheers
www.turn3autosport.com
Old 04-05-2008, 11:00 PM
Sherwood
Want to explain how??
Rick
88 Cab
Old 04-06-2008, 08:01 AM
