-   -   5 Amp fuse. Where do I get one? (http://forums.pelicanparts.com/porsche-911-technical-forum/40222-5-amp-fuse-where-do-i-get-one.html)
Blackdimonds 05-09-2001 06:20 PM
I cleaned up my fuse box, and I broke one of the yellow 5 Amp fuses in the process. I can't seem to find them at any auto parts places. Even Pelican and other vendors do not offer the yellow 5 Amp fuse. Where do I find these things?
Help!!!
Paul
81 911SC
campbellcj 05-09-2001 07:45 PM
Did ya try your local Porsche "stealership?" ahem I mean "retailer"?
Believe it or not, for certain little nuisance items like this, their prices are about the same as everybody else's, and they often have the stuff in stock...
ClayMcguill 05-09-2001 08:48 PM
Couldn't you just break a 10 amp fuse in half, and use that? Then you'd have a spare!
Sorry, a weak attempt at humour there. Seriously, try Radio Shack.
Clay McGuill '66 912, '97 Jeep Cherokee www.geocities.com/the912guy
Blackdimonds 05-09-2001 08:58 PM
Thanks guys, I did try the local Porsche dealer, and they said "no we don't have those, just use a 8 Amp." I have yet to try Radio Shack, I will try them tomarrow.
Thanks,
Paul
81 911SC
JDaniel 05-10-2001 05:43 AM
I went through the same search a couple of years back. No one nearby seemed to stock 5 amp fuses. Then, on a little driving excursion, I stopped into a NAPA store to buy some oil. Lo and behold they had all types of german fuses (although they were the glass type and not the OEM Porsche). I bought every 5 amp fuse they had!
I guess it pays to just drive around and look in every car parts store.
Dan Tolley
1987 911 Coupe
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294
Allan Broadribb 05-10-2001 06:58 AM
Drop into Discount Auto Parts - I think they call them European fuses.
Allan Broadribb
'70-911E, 2.2l with Webers
http://www.cheaterswayside.com/uploads/Mvc-002s355.jpg
Blackdimonds 05-10-2001 03:30 PM
Thanks Dan, I stopped at a NAPA today, and BINGO they had them. Here is the NAPA part # if you need some (782-1102). They had 5 of the original yellow type, and then I ordered 10 more that I believe are the glass type (the guy at NAPA said that they are the same thing, just in a different style). All the 8, 16, and 25 AMP fuses on the shelf were the glass style.
Paul
81 911SC
oly 12-13-2006 06:37 PM
Our local NAPA only had the clear glass tube type. Pelican still does not have them. So I got them from Sunset Imports, P/N 900-173-006-90, for $0.43 each. They are yellow instead of the pink (orginally red maybe?) ones that are in the car.
Early_S_Man 12-13-2006 07:57 PM
Littlefuse or Buss GBC 5 fuses are either the ceramic style as the OEM German fuses, or they can be glass with soldered conical ends. See pics, here:
http://forums.pelicanparts.com/showthread.php?s=&threadid=317812&highlight=little fuse+fuse
Wil Ferch 12-14-2006 07:20 AM
Quote......"I did try the local Porsche dealer, and they said "no we don't have those, just use a 8 Amp." ..."
Idiots !!!! .....8 amp is 60% ( ! ) higher than spec value....and we wonder why we have electrical problems when Porsche's designs are poor ( not enough fuses), and when we do use fuses....they're 60% stouter than spec....
Stupid Porsche dealer idiots !!! ...........
- Wil
Jim Sims 12-14-2006 07:37 AM
Actually in terms of power or heat generated in the wires when it finally blows an 8 amp fuse is 156% higher than a 5 amp fuse.
Zeke 12-14-2006 07:38 AM
What is the mn wire size to be protected by a 5 amp and what is the min wire used in a 911?
304065 12-14-2006 08:05 AM
Ahh, Jim! I-squared R, right?
5 amps squared = 25
8 amps squared = 64
(64-25)/25 = 156%!
Wil Ferch 12-14-2006 08:47 AM
The point still remains that there is a "reason" for a 5a rated fuse to exist... and to have an official-sounding recommendation from a Porsche facility to suggest use of a 8A instead...is insane and borders on the criminal.
Take it from someone who had a $3000 wire-harness fire due to similar reasons on actions done by the PO. I guess I'm "funny" like that ....
- Wil
304065 12-14-2006 09:03 AM
Yep, Paul, there's your answer. . . and it only took five years, seven months and three days for the Board to reply!
Paul?
Paul?
Wil, let's hear about this harness fire of yours!
Wil Ferch 12-14-2006 10:25 AM
It's a rather long involved story.... cliffs note version follows:
Some kind of relay behind the dashboard failed internally ( random fluke ?)...where an internal piece broke off and landed on the "other" ...control side... of the relay circuit. The control-side of the circuit was now energized from the "power side"....and the control side was "protected" by an improper ( too-high amp rating) fuse installed that caused that circuit ( normally 5A, interior lighting) to fry, smoke, and melt. Car was smoking in the cockpit, and as I stopped the car and turned the key off and out....the car kept on running and smoke continued to pour out of every vent and thru every orifice in the cockpit. Quick run to the engine compartment and pulling wires got the car to stop running....followed by a quick sit-down to get the adrenaline out of your knees.
Fix.....completely new wiring harness ( "sorry...none in the USA...hafta ship from Germany"). Work involved removing all gauges, gas tank, steering, rewiring the front-end of the car and under the dash, cruise control wiring, etc.....
Upside?....the people doing the work were anal and fastidious such that point-to-point wiring as well as clipping / clamping was done totally to factory specs. Today, there is no hint of having had any problem, and I now have newer wires ( no corrosion, still subtle insulation)...and may have come out of this ordeal even better than OEM... by being newer.
But still $3000 for parts / labor / downtime and research to do "right"....
- Wil
Jim Sims 12-14-2006 10:46 AM
It's times like this that I really appreciate Mr. James Placek's high school physics class. If you get out of high school not knowing P=I^2R you've been cheated.
Jim Sims 12-14-2006 12:52 PM
"What is the min wire size to be protected by a 5 amp and what is the min wire used in a 911?"
Ampere capacity depends on wire insulation type, bundling and duty cycle (how long the circuit will be on) but here are some conservative values for copper metric wire based on 80 deg C rated insulation and wiring bundles containing 16 to 30 wires.
.6 mm^2 wire: 5.8 amps
1 mm^2 wire: 9.65 amps
1.5 mm^2 wire: 14.5 amps
2.5 mm^2 wire: 24.1 amps
6.0 mm^2 wire: 57.8 amps
mm^2 means area cross-section in square millimeters.
I recall seeing all the above metric wire sizes in a 911 wiring diagram.
This is based on about 200 circ mils of copper per amp.
Some very conservative wiring codes require 700 circ mils of copper per amp.
stallturn 12-14-2006 01:49 PM
Re: 5 Amp fuse. Where do I get one?
Help!!!
Paul
81 911SC
Hi Paul
Try eBay, just ordered 50 of them at various values(5 included) here in the UK cost around $12.
hope this helps.
wallstreet 02-08-2012 05:40 PM
There is a pack of glass fuses on ebay. Ciurrently. 8/16/25 amp and ask for 5's. GLASS TYPE for less corrosion
Dan Tolley
1987 911 Coupe
cheaterswayside.com
John W. 02-08-2012 08:30 PM
I just checked. Pelican carries 5 amp fuses now.
wallstreet 02-08-2012 09:36 PM
Ceramic or glass.
Joe Bob 02-09-2012 06:26 AM
11 year old thread? Oiiiphffff.....
wallstreet 02-09-2012 08:24 AM
OK so you bought your last part 11 years ago. What does that have to do w/ buying a non-ceramic fuse that is difficult to find for someone else's 911 or 928? Ommphphffff !:confused:
Seriously, anyone looking to gain an edge on maintenance of an electrical system might consider a glass type fuse. I realize this person or even you are not interested but others might. This thread was merely an entry to remedy a problem many Porche/VW/Volvo/BMW owners have for more than 11 years. I looked for glass fuses for several months to replace corroded ceramic fuses. Once the new fuses were installed, my time consuming maintenance cleanup was a minimum. I was just passing on a small piece of information to anyone interested.
Sorry if you were offended.
Joe Bob 02-09-2012 08:33 AM
You're missing my point....the OP and follow ups would have asked more questions if they couldn't find what they needed.
The OP isn't even a registered user, will not get a response nor will anyone benefit from a crusty old thread.....but hey, have at it.....
wallstreet 02-09-2012 09:02 AM
You're missing my point. I was not specifically addressing OP. I was not even expecting a response... from anyone. The fact that no one asked does not mean more information is added.
As stated, I was passing on some information others might be interested in regarding either 5 amp GLASS fuses or glass fuses in general. It obviously is not of interest to you except to make a off handed opinion. Your opinion is understood. If the fuse issue does not apply to you then use the delete key. Many owners have had a corrosion issue and maybe never knew a replacement was available.
"but hey have at it"
hbueno 02-09-2012 11:00 AM
I don't mind the old thread resurrection.
I've been on the prowl for glass GBC fuses myself. NAPA Online shows them as being in stock, but I haven't tried ordering to see if they will send glass or plain old plastic or ceramic fuses. I never thought of checking on ebay.
wallstreet 02-09-2012 11:35 AM
Thank you
This could be a source:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I paid dearly for mine as I had experience from the Volvo several years ago. I called the Volvo dealership and they said "nothing like glass fuses exist". Altho I purchased from them years earlier.
I also checked NAPA, OReilly's and others. They showed an SKU but zero inventory.
Hope this helps.
hbueno 02-10-2012 05:01 AM
Last night I found a vendor on eBay who had four packages of Bussman glass fuse assortments. I pulled the trigger and bought them for just under $20 total including shipping.
wallstreet 02-10-2012 06:40 AM
Great... then resurrection IS good.
