(the shotguns)
berettafan's Avatar
Is there some kind of trick to getting fuel hoses onto the tunnel lines?
Trying to install my new fuel lines on the front end of the tunnel and i can't get the smaller line on. Problem is my fingers are just too fat!
Any thoughts/ideas on this? I am big time anxious to get this thing back together.
Old 04-11-2008, 08:34 PM
burgermeister's Avatar
Did you cut the crimps and now you're pushing new rubber lines on?
I used 5/16 fuel injection line - went on without a hitch. Try some spit on the fitting - sometimes does the trick, and is usually handy even when lying under the car. Downside is a bad taste sensation ...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 04-11-2008, 08:46 PM
Danny_Ocean's Avatar
Silicone spray? Silicone grease?
Old 04-11-2008, 08:48 PM
Warren Hall Student
Bobboloo's Avatar
I usually out a little vinyl/rubber protectant on the end to lubricate it.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-11-2008, 08:54 PM
Lubricate the fitting and hose then heat the end of the hose with a hair dryer.
The heat softens the rubber allowing it to stretch much more easily. Get it
good and warm. Works on all rubber hose fittings.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 04-12-2008, 04:51 AM
(the shotguns)
berettafan's Avatar
Thanks guys!
I think between spit and a hair dryer i should be in good shape. my concern was that anything that lubricates the hose going on would make it that much easier to remove.
Old 04-12-2008, 05:34 AM
