Question on 3 Pin CDI BOSCH
Hello,
i've an old 3 Pin CDI with ZX82 Zener died.
It's difficult to have this kind of zener here.
If i use a TVS(transient volatage suppresso) as 1.5KE 82A (82 volt)
is ok or not?
Thanks for any Help
Bye MAX
Old 04-08-2008, 06:01 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The 82V Zener sounds about right.
Also....check the SCR which is screwed into the housing (heat sink).
I replaced mine with one that was rated at 40A instead of the original which is rated at about 6A.
Use heat sink compound like Wakeman's.
Run all the traces with your iron if necessary to eliminate breaks.
Good luck
Bob
Bob Hutson
Old 04-08-2008, 06:54 AM
