SeaDweller
Guest
Posts: n/a
Question Painting Fiberglass Shroud
I put a few coats of primer on my fiberglass shroud, and it seems to come off (down to the fiberglass) pretty easily.
For those of you who have had a lasting paint job on your fiberglass shroud, how did you do it, and what kind of primer and paint did you use?
Thanks!!
Michael
'78 911SC Euro
Old 05-10-2001, 02:15 PM
Jim T
Guest
Posts: n/a
Post
I sanded mine and used engine block spray paint. No primer, just sprayed it straight on.
I actually tried first cleaning it with cleaners, then tried buffing it out to clean it up, then tried sanding to see if I could get it as clean as I wanted. Looked better, but not good enough, so I painted it.
Held up perfectly so far, its been a few years now.
Old 05-10-2001, 02:20 PM
Fishcop
Guest
Posts: n/a
Post
Sand it with 600 grit then use a two part (hardner) primer. Paint shouldn't let go then!
Good luck
John Forcier
69 911T
Old 05-10-2001, 05:36 PM
atr911
Guest
Posts: n/a
Post
Just like they do on those Plasic Pieces of Crap (vettes). Use a self etching primer, then paint. With all the possible contaminants on that shroud, I would deffinetly clean and prime first.
Adam Roseneck
Old 05-11-2001, 07:04 AM
