Do it yourself alignment and corner balancing questions?
Has any one done this them selves? I know I can set toe caster and chamber. The problem is when you mix in corner weights. How should I go about doing the alignment and corner balance. Should I set height then go for corner weights? Should I do an alignment then set corner weights and recheck alignment again? How should I go about this? I have a 80sc. Car is stripped out and has a cage. I have chamber plates monoballs and 23 and 31 size torsion bars. Tires will be 225 and 245 16's. Car will be set up for autocrosses and de's so I'm looking for a track alignment. Do I have to put my weight in the car when I do this, or should I just use the weight of the car?
Set ride height,
balance.. Align.. Sometimes you need to fiddle a bit |
| All times are GMT -8. The time now is 07:34 AM. |
