Creepy sound post #2 (Chain tensioner photos)
Ok. my older post and here some photos of my left side chain box
![]() ![]() ![]() ![]() ![]() ![]() ![]() What do you think? How bad does it look? Does this tensioner look totally collapsed?
X/A |
Well, I can't comment, as you have the older tensioners, but I'll bring it to the top for you. It's hard to tell. Do you have the the 'stop' devices on those tensioners?
Did you open the right side as well or did you determine that the sound was coming from the left side?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Per your video, I too think it's a collapsed chain tensioner. Classic audio symptoms.
Since you have the cover off, to confirm, use a long flat-blade screwdriver as a lever and try to lift the idler arm upward where it contacts the tensioner piston rod. It looks collapsed anyway, but if the rod or the idler arm can extend further, the oil has escaped from the tensioner. Either rebuild or replace the tensioner. Most owners replace with the later "Turbo" chain tensioners or the pressure-fed tensioners that appeared in 84'-on 911s. Check your budget, then proceed. BTW, the other side soon follows. It's also recommended to change to the '81-on idler arm with wider pivot bushings. Some say the narrow bushing idler arms exacerbate tension failure. Sherwood |
well, when I was checking the left side I did the what you said with the screwdriver lever and yes the sprocket moved like 5mm. so this is it, right? the right side looks ok; at least better than the left side.
here are some photos of the tensioner unpressed. ![]() ![]()
X/A |
"well, when I was checking the left side I did the what you said with the screwdriver lever and yes the sprocket moved like 5mm. so this is it, right? the right side looks ok; at least better than the left side.
here are some photos of the tensioner unpressed." It appears so. BTW, the right side tensioner will soon follow. You may wish to repair/replace both at the same time. In addition, keep an eye on the proximity between the idler arm and the chain box housing. The tensioner normally extends to compensate for wear in the idler arm/chain system. If it gets too close to the housing, especially on the left side, that might indicate a worn chain and/or sprocket(s). Sherwood |
Thanks! I will replace both and also the idler arms chain and ramps, a fast jet cleaning to the new for me brush headers and a teflon coating also I'm going to change my muffle for a 2in 2out magnaflow part#11378
Thanks for all please keep checking the thread. BR
X/A |
Author of "101 Projects"
I wouldn't have even bothered taking the photos - I would have just replaced those tensioners with the Carrera kits...
I have them in stock, on the shelf (they were getting difficult to find, so I bought out my supplier's remaining stock). -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
THX!
X/A |
It looks like your hose is split and frayed in the 2nd picture.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
