Guest
Posts: n/a
Does anyone know the diameter or radius of the oil line (smaller one) that feeds the Carrera style tensioners? Here's a picture of what I mean... http://www.pelicanparts.com/techarticles/911_carrera_chain_tensioners/pic20.jpg Thanks! Matt |
Guest
Posts: n/a
Outer diameter or inner diameter? And why do you need to know?
-Wayne |
Guest
Posts: n/a
I'm curious to know exactly what the force range is for the tensioner over in the RPM domain (for the oil that is, not just the spring), so inner diameter would be the answer (figured outer would be easiest to get). Matt |
Guest
Posts: n/a
Doh! Double post...
[This message has been edited by lucky77 (edited 05-13-2001).] |
