-   -   3.2 911 No Spark Condition seek advise (http://forums.pelicanparts.com/porsche-911-technical-forum/403590-3-2-911-no-spark-condition-seek-advise.html)
keyla 04-13-2008 04:30 AM
I started my stock 86 911 and started immediately as usual.Pulled out of the garage and it shut down,no spark at the plug.Any ideas on what/where to check for usual cause?Just thought I would ask on here before I begin to check. Thank you.
MBEngineering 04-13-2008 04:40 AM
HI keyla
check the DME (DEE) relay under the seat
http://forums.pelicanparts.com/uploa...1208086690.jpg
the 2nd fault in on the test plan is the DME (DEE) relay if the earth's are OK
http://forums.pelicanparts.com/uploa...1208086720.jpg
good luck.
regards mike
keyla 04-13-2008 04:47 AM
Thanks Mike after my breakfast I will check it.
keyla 04-13-2008 06:04 AM
Cleaned the terminals with electronics cleaner and car started right up? Hope thats it.Thank you.
Gunter 04-13-2008 08:51 AM
Consider carrying a spare relay. :)
keyla 04-13-2008 09:00 AM
Do you know the part number Gunter?
MBEngineering 04-13-2008 12:02 PM
HI keyla
the DME (DEE) relay No' is 911 618 154 00 will find the aftermarket No' for you tomorrow.
regards mike
db_cooper 04-14-2008 06:16 AM
I just replaced mine, as a precaution, on my 911. The aftermarket part number is 3.308.100 made by K.A.E. in Berlin, as supplied by our host at a very reasonable cost.
The original Bosch part had the time date imprint 24, 06, 85 and the manufacture date of my car is 7-85. Of course it had "made in W Germany" on the relay.
I wonder if the new part would have a service life of 23 years too?
