mca mca is offline
mca's Avatar
Cam Woodruff Key Stuck - Need Advice on Removal
I am tearing down a 3.0 for a rebuild.
Today I was able to remove the left camshaft assembly (nut, sprockets, tens, etc), remove the heads, and remove the cylinders.
However, on the right side I can't seem to remove the cam woodruff key. It seems to be stuck pretty good. Tried using needle nose pliers to pull on it with no luck. The back side of the woodruff key is raised more than the front so it is kind of difficult to get behind it in order to pry it out. Any suggestions?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 04-12-2008, 06:21 PM
Fritz Peyerl's Avatar
woodrof key
use a pair of side cutters. squeeze the key between the jaws and push the pliers against the cam shaft, those lifting the key out of the groove.
Old 04-12-2008, 06:36 PM
before using side cutters, get a hammer and screwdriver, set the screwdriver in line with the camshaft, up against the end of the key, and tap it a few times to move it out of it's keyway.
206 637 4071
Old 04-12-2008, 07:06 PM
mca mca is offline
mca's Avatar
I tried that tenatively. The key looked chewed compared to the left side. I wonder it the PO had a similar problem.
Anyhow, I will give that a shot again ... using a little more force.
Old 04-12-2008, 07:14 PM
When you do this, be prepared to catch the flying key. Do you realize how many places a flying woodruff key can hide? One place is inside the engine. Apply a piece of sticky tape onto it to slow down its velocity as it takes off.
Sherwood
Old 04-12-2008, 07:20 PM
peppy's Avatar
mca I used the method John described. Just be careful not to drop it in the engine case like I did.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
mca mca is offline
mca's Avatar
You know, I was thinking about you when I was removing the key on the left side today! I must admit ... I chuckled a little. Not because of your misfortune but because it makes all of the gifted people on this board seem human.
When looking at it I don't understand how it can get inside the engine. How did yours get in?
Any luck getting it out?
Old 04-12-2008, 07:24 PM
mca mca is offline
mca's Avatar
.... oh, I know ... chain/crankshaft area right?
Old 04-12-2008, 07:30 PM
peppy's Avatar
Yes the chain area. No, I have not gotten it out. I can not even see it in there, but the chain ramps are still in. I will try again next week some time.
Did you get the key out?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 04-12-2008, 07:54 PM
mca mca is offline
mca's Avatar
Yes, got it out. Just used a little harder force than I had initially used. Trying to err on the side of caution.
I hope you can retrieve yours - will be checking your thread for updates.
Old 04-13-2008, 11:53 AM
