Cam Woodruff Key Stuck - Need Advice on Removal
I am tearing down a 3.0 for a rebuild.
Today I was able to remove the left camshaft assembly (nut, sprockets, tens, etc), remove the heads, and remove the cylinders. However, on the right side I can't seem to remove the cam woodruff key. It seems to be stuck pretty good. Tried using needle nose pliers to pull on it with no luck. The back side of the woodruff key is raised more than the front so it is kind of difficult to get behind it in order to pry it out. Any suggestions?
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
woodrof key
use a pair of side cutters. squeeze the key between the jaws and push the pliers against the cam shaft, those lifting the key out of the groove.
before using side cutters, get a hammer and screwdriver, set the screwdriver in line with the camshaft, up against the end of the key, and tap it a few times to move it out of it's keyway.
Anyhow, I will give that a shot again ... using a little more force.
Sherwood |
mca I used the method John described. Just be careful not to drop it in the engine case like I did.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
When looking at it I don't understand how it can get inside the engine. How did yours get in? Any luck getting it out?
.... oh, I know ... chain/crankshaft area right?
Yes the chain area. No, I have not gotten it out. I can not even see it in there, but the chain ramps are still in. I will try again next week some time.
Did you get the key out?
Yes, got it out. Just used a little harder force than I had initially used. Trying to err on the side of caution.
I hope you can retrieve yours - will be checking your thread for updates.
