Registered Speed Offender
Hey group...
I just pulled the engine and transmission together and had a question: There is a rubber encased set of two wires that run from the front of the transmission back to the engine. The two wires look to be 16-guage. One is green with a yellow stripe, the other is gray with a brown stripe. They attach at the very front of the 915 tranny, beside the shifting shaft. Can anyone tell me what the function of these wires are? Thanks !
Crazy Horse ______________ 1989 930 |
Semper drive!
If you're talking about these wires, those would be for your reverse sensor.
![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Tranny wires..........
Those two wires go to the backup light switch. The connection to the chassis is made at the 14 pin connector next to the electrical center in the engine compartment.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
hey, that is the ones I was asking about. I appreciate the help !
If that is the reverse sensor, then what is the single black wire going mid-way into the passenger side of the 915? Please let me know. Thanks !
Black wire.......
That's the speed sensor for your speedometer. If you want to learn more about your car, get some reference manuals like Bentley's or Haynes' for starter. Factory manual is much better. Having these manuals available to you would help you learn more about your car. Good luck. Tony |
