Follow me
seymore's Avatar
Speedo question
I just bought a new/used speedo with more mileage than is actually on my car. Was wondering if anyone knows if you car turn the miles back to match the one I have now?
Old 04-13-2008, 05:04 PM
3.2 CAB's Avatar
It is done quite often at the speedometer shops. People will have to have a replacement speedometer at times, and they get the speedometer shop to repair, service, calibrate, and set to correct mileage. If you go this route, be sure to keep the documentation of this being done, to keep with the records of the car.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-13-2008, 07:40 PM
I recently replaced a gear in mine to fix a common odometer issue. There was a 50,000 Mile discrepancy on my title back in 98 and who knows how long the odometer hasn't worked since it broke. I didn't feel bad at all about rolling mine to a nice even number.
If you decide to take yours apart
***DO NO PULL/PRY the Speedometer needle off***
Carefully rotate the needle all they way until it stops. When you have reached the stop keep spinning it and lightly pull up at the same time. The pin the needle rides on is essentially a wire - there is no glue - It's just a friction fit but it can be bent or broken if you aren't careful. I went back and forth to the low and high stop a few times with mine and it came off very easily. Installation is very similar.
1989 Carrera 3.2L in 993 bodywork
Old 04-13-2008, 10:35 PM
