Armed Bastard
djb25's Avatar
CIS - cold pressure very high
Hi everyone,
I have been working on a cold start problem with my car for a couple of weeks now (off and on working on it, that is). Car is a '77.
In a nutshell, the car fires and then stalls immediately.
I hooked up some gauges and found my cold pressure to be around 70 psi... exactly the same as my system pressure.
I've determined that this pressure is way too high... but I don't know where to go from here!
Any help would be greatly appreciated!
- Damion
'77 911S
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 04-10-2008, 05:12 PM
grateful user
don gilbert's Avatar
blocked retun line, unscrew return line ane see if you can blow air through it towards the tank
Old 04-10-2008, 07:11 PM
UnRegistered User
billybek's Avatar
Another good reason to give up smoking!
Bill K.
Old 04-10-2008, 07:22 PM
sudo apt-get purge 930
equality72521's Avatar
What?
--clutch-monkey
Old 04-10-2008, 07:30 PM
Control pressure.....
Damion,
Do what Don suggested. I was doing a start-up test for a friend's car after an engine installation. And this was exactly what we had, very high cold control pressure as high as the system pressure. The problem was blocked fuel return line. After correcting and fixing the return line, the car is now running without any hesitation at start.
Did you have any work done on the fuel line system before this happened? Like an engine removal and installation? Keep us posted.
Tony
Old 04-10-2008, 07:39 PM
Armed Bastard
djb25's Avatar
Hi everyone,
Don was dead-on.
The screen in the WUR was filthy. I imagine this happened when I pulled the gas tank last fall to replace the front suspension pan.
I pulled the WUR and cleaned it out, the car is back to running and idling well.
Thanks everyone!
- Damion
Damion
Old 04-10-2008, 08:45 PM
grateful user
if your tank has been sitting for a while, there is a 90 degree bend inside the tank where the return line goes in, fuel sitting there for a period of time will solidify. brake cleaner and a flexible rod (i used a piece of cable) will fi it
Old 04-12-2008, 05:58 PM
Armed Bastard
djb25's Avatar
Don,
That's something I've never heard of before... fortunately, cleaning the WUR fixed my problem.
I definitely am going to have to purchase a new fuel filter, though.
Thanks again, everyone!
- Damion
Damion
Old 04-14-2008, 05:48 AM
