1974 open-ended corded rubber pipes
i Guys,
A few Questions, Whilst fixing the windscreen washer pipes/motors on my 1974 911 car I found the following, two series of open-ended corded pipes in the hood/bonnet area running alongside the fuse panel battery area. 1) corded rubber pipe one starts at the brake servo unit-overflow pipe? 2- corded rubber pipe two which starts around the fuse panel area, which smells of fuel,so much so that drawing a vaccuum on it will appear to draw fule, i'm particularly worried about this pipe. Both pipes are open, and I'd pushed them out through the front wing grommits for now . are they supposed to be open ended? Cheers, Jaz
http://www.juswant.btinternet.co.uk |
Friend of Warren
One probably is the master cylinder overflow and the other goes the the charcoal canister.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I'll bet your car doesn't have the vapor emission control system--expansion tank, collection tank, charcoal canister. The hoses you describe, along with the smell of fuel, suggest some or all of the components are missing. Do a search, there have been some excellent diagrams posted in the last week which covers this exact topic.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Thanks, where would I find the charcoal cannister , is it in the front/hood/bonnet, what does it look like.
Regards, Jaz
