Superman
Guest
Posts: n/a
Post Musings
I've said here recently that these cars are a DREAM too work on compared to all other cars. Well, the other day I was whining to myself about the pain-in-the-neck A/C compressor I need to move in order to adjust valves properly. I was thinking when I remove my motor, maybe I'll take out all the A/C stuff. The car would probably loose 100 lbs, and I could avoid moving the compressor for each valve adjust. Then....
I came to my senses. I said "What are you doing whining about removing three quality fasteners that are easily accessable and just laying the compressor across the air box?" Then I remembered working on my wife's '73 Pontiac Lemans. THAT compressor was a WAY bigger pain than this one.
"Sheesh" I said to myself. These cars are near perfect.
'83 SC
Old 05-15-2001, 10:33 PM
