MIK911's Avatar
930S steering wheel sounds... "scratchy"
Started noticing a scratching sound as I turn my steering wheel. Sounds like plastic rubbing on plastic. New problem on a 930S wheel i've had for awhile. Before I start tearing it out/down, anyone ever experience this, and have suggestions as to what to look for/ or fix?
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 01-26-2008, 06:36 PM
sudo apt-get purge 930
equality72521's Avatar
Check your steering wheel bearing by pulling the wheel and looking at the plastic "race". Chances are it's bad, this is common.
--clutch-monkey
Old 01-26-2008, 06:44 PM
- Self Moderating -
Pelican sells an "quick fix sleeve" that goes in the column to tighten things up. This might be what you need. Do a search it has been discussed many times before.
Tim
Present: 57 Intermeccanica Speedster Ivory on Brown
Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan
Old 01-26-2008, 07:37 PM
78P930's Avatar
The horn contact may need some dielectric grease.
10 Ford Raptor
86 930
Old 01-26-2008, 07:45 PM
Jeff Alton's Avatar
I also suspect the horn contact. Nice easy free fix...
Cheers
www.turn3autosport.com
Old 01-26-2008, 09:17 PM
Paul K's Avatar
No scratching when I installed mine- but there is a loud click from the turn signal cancel when I turn the wheel. Anyone else experienced this?
Cheers,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 01-26-2008, 09:20 PM
Virginia Rocks!
VaSteve's Avatar
Cheers
That's what it sounds like to me.
Cheers,
Paul.
Paul, almost sounds like it was install improperly. Has it been installed for a while? I took my wheel off to recover it and reinstalled it wrong...I had issues with the canceller as well.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-26-2008, 09:28 PM
MIK911's Avatar
Cheers
Thanks for good suggestions. Regarding the horn contact, does it simply need to be bent?
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 01-26-2008, 10:03 PM
abrumley's Avatar
do you still have the c-clip on the column?
Old 01-26-2008, 10:21 PM
Gordo2's Avatar
Plastic Rubbing
My car had a nasty plastic rubbing sound for a while and then one day became very wobbly (as in you could move the whole wheel up/down, left/right by ~1/4in). Kind of freaked me out at first until I hit the board and searched for steering wheel wobble and found loads of threads describing the problem and easy fix - as mentioned in the other posts: replacing your steering shaft bushing.
When the bushing begins to go bad, your steering wheel can sag/sit lower allowing the back of the wheel to come in contact with the plastic steering column housing (that covers your turn signal switch).
The picture shows my old bushing (green part) hanging around the steering shaft. Replacement is simple - search steering wheel wobble. Your problem may just be associated with the horn contact (the metal tab in the picture), but if your wheel feels like it wobbles some now, you may want to buy the metal replacement bushing and be done with it in one shot.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-27-2008, 01:05 AM
Does that bushing work on early 70's cars?
Old 01-27-2008, 08:46 AM
msk1986911's Avatar
Make sure you lube the metal bushing well before it is installed. There was quite a bit of discussion on that topic a few months back.
Old 01-27-2008, 09:01 AM
HarryD's Avatar
I am not sure what you mean by early 70's but for my '73 the 928 bushing will not work. Check this thread: HELP! Steering wheel bushing quickfix???.
What year is your car? Please add it to your signature to make answering these questions easier.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-27-2008, 10:43 AM
AutoBahned
RWebb's Avatar
And, Harry, your car is technically a '73.5 which has few different things than an early '72.... right? (I'm looking at your sig.)
Old 01-27-2008, 11:01 AM
HarryD's Avatar
Wise Guy.....
Yes it is slightly different than the '72's and early '73's.
If you must know, the '72's and most of the '73's had a Bosch MFI system for fuel induction (We will ignore the '72 oil filler flap as yet another difference). In mid-'73, Porsche introduced the Bosch CIS fuel induction (K-jetronic) system for the 911T's (and I know how much you like them ). In '74 all Prosche 911 had CIS.
The gentleman who asked the question, wanted to fix his wobbly steering wheel. As part of the changes in 1974, the steering wheel bushing changed and the 928 part is a viable fix for that issue.
OK good buddy?
Harry
2020 MB E350 4Matic
Old 01-27-2008, 11:15 AM
steve911's Avatar
John Walker posted an advisory that you should grease the replacement when installing
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 01-27-2008, 11:36 AM
MBAtarga's Avatar
I had a similar noise. I had already installed the bushing, so removed the steering wheel and added some grease per JW's suggestion. Reinstalled the wheel, and the noise was still there. Did several searches - someone suggested somewhere that the steering wheel lock mechanism might be causing the problem. So following that thread, I drilled and inserted a screw to hold the lock from engaging. Reinstalled the wheel and it seemed to have gotten rid of the noise. Until yesterday - the noise is still there. Not sure what's causing it - but it's not the lock mechanism.
Mark
'83 SC Targa - since 5/5/2001
Old 01-27-2008, 11:58 AM
Designer King
Paulporsche's Avatar
Did you put some grease on the horn contact?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-27-2008, 12:21 PM
HarryD
How is this? Just figured how to do it!
Randy
Randy
73.5 911 T
97' C2S
06' C2S
Old 01-27-2008, 03:56 PM
HarryD's Avatar
HarryD
Randy
Very nice....
I presume your problem is with the '73.5 T then. The biggest problem is finding replacement parts if you lost them.
Harry
2020 MB E350 4Matic
Old 01-27-2008, 04:37 PM
