-   -   What hose goes into this connection? (http://forums.pelicanparts.com/porsche-911-technical-forum/403898-what-hose-goes-into-connection.html)
liskeard 04-14-2008 05:19 PM
Engine is out, and I've never had this connected. I figured since I'm working other 'issues', i'd figure out what should go here. I do have another lone hose that might belong on this fitting.
http://forums.pelicanparts.com/uploa...1208218694.jpg
I also need to track down the part number on Pelican Parts site for this hose and for my Crankcase Breather hose. I always get into the parts list then don't quite see the hose in the parts breakdown.
Any help is appreciated.
Thanks ... ted
john walker's workshop 04-14-2008 05:22 PM
comes off the front of the throttle housing, vacuum at idle. probably disconnected and plugged, laying back there somewhere, because with it connected, the idle would hang.
liskeard 04-14-2008 05:56 PM
Great, it is diconnected and plugged, so I'll track it back to make sure that's the correct dangling hose.
So, your saying keep it disconnected, sounds like a plan. I may clean up the hose and shorten it to tiddy up a bit.
Thanks ...
