Guest
Posts: n/a
Here is an update on my bent valve.
Got the engine out of the car and I tore everything apart. I really whacked the #3 intake left a mark on the piston and I was unable to get the valve out of the head. Shipped the heads off to EBS so they could work their magic to the tune of $1200 OUCH For that I am getting Standard valve job (3 angle grind) $395 resurface heads $125 12 valve guides $54 12 valve seals $18 3 intake valves $66 3 exhaust valves $96 Head gasket set $168 12 valve springs (set) $96 1 used cylinder head (old one was cracked) I should have them back by May 28 which will give me 3 whole days to get everything put back together for Porsche Fest here in Charlotte NC. I don’t think that is going to happen. Everything has gone smooth except I am still missing a valve keeper that got knocked off the #3 intake. I have fished through the case with a magnet but haven’t found it. Where could it have gone? Right now everything is off the engine except the cylinders as I didn’t want to worry about getting those back on correctly beside those case through studs are expensive and I think they are stretch bolts (correct me if I am wrong). Wish me luck and as I install a new clutch and upgraded tensioners. Osidak 78 911sc Targa (what’s wrong with a targa by the way) [This message has been edited by osidak (edited 05-16-2001).] [This message has been edited by osidak (edited 05-16-2001).] |
Guest
Posts: n/a
What is "fly cut heads"?
------------------ '86 Cab, '77 Targa, Family Truckster |
Guest
Posts: n/a
resurface the heads = fly cut
Guest
Posts: n/a
So this is shaving the mating surface. What is the resulting compression increase?
Guest
Posts: n/a
Osidak,
There's nothing wrong with a Targa! Why do you ask? The wandering, missing valve keeper might be in one of the oil return tubes ... Actually for what you are getting from EBS, ir sounds like a great deal! It could easily have been $1500 or $1800! Why, if you don't mind me asking, are you only replacing 3 sets of valves? At those bargain prices, you ought to do ALL OF THEM! ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Warren,
I am replacing the 6 valves because they say those got bent also. The other valves according to them are in great shape. My wallet is screaming at me so I figure if they say they are in good shape I might as well save a few dollars. I ask what is wrong with a targa because it seems many on this board do not care for them. I love mine. Clark, I do not know what the compression increase will be but I would image I won't see any hp gains as I loose a little clyinder volume as well. Osidak |
Guest
Posts: n/a
warren,
looked in the oil return tubes no luck there, i pulled the oil strainer and went looking in the case and didn't find anything. ran a magnet all through there couldn't find the damn valve keeper but I did find a piece of the valve stem seal. any ideas osidak |
