<insert witty title here>
Christien's Avatar
Engine/tranny mounts
Ok, stupid question - I've got my engine and tranny out to rebuild the tranny, and I'm ordering parts today. Are motor and transmission mounts exactly the same? If so, I should just order 4 of the same part #? (911-375-043-07-M127)
Thanks!
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 04-16-2008, 07:29 AM
Somatic Negative Optimist
Gunter's Avatar
Yes, they are interchangeable.
911-375-043-07-M127 are the Sport Mounts, very nice.
The difference is a smaller diameter center sleeve and slightly stiffer rubber.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-16-2008, 10:17 AM
Christien's Avatar
Awesome - thanks!
Old 04-16-2008, 10:31 AM
Gunter's Avatar
When you put everything back in, leave the 4 bolts that connect the transmission crossmember to the transmission just snug/moveable so aligning of the 2 main bolts going through the mounts into the body is much easier.
The same with the engine crossmember; leave the 4 bolts going into the engine case just snug, then torque the two M12 bolts (60 ft-lbs with lube)
Once you have the four M12 bolts torqued (60 ft-lbs with lube) tighten the 4 remaining fasteners on the transmission crossmember and the 4 bolts from the engine crossmember into the case.
You'll achive 2 things with this:
Easier finding the holes for the 4 main M12 bolts and:
The engine/transmission will self-align as a unit without introducing stress.
Old 04-16-2008, 11:52 AM
Christien's Avatar
Great idea - thanks for the tip!
Old 04-16-2008, 12:28 PM
