Bob Prosser's Avatar
Anyone rent the jig for drilling out broken exhaust studs (3.2)
Hey all. While having the valves adjusted on my 3.2 Carrera (at a reputable Porsche shop), I was told I have a broken exhaust stud in #3 cylinder. They quoted $500 for the job. Bummer!
I am a DIY type on basic tasks, so I was wondering if anyone rents the jig needed to drilling it out?
I also wonder, when the exhaust systems comes off will the act of removal break others?
- Bob
Old 04-16-2008, 08:09 AM
Will program for food
ghnat's Avatar
AQUIETBOOM (on this board) sells a tool for just this purpose. PM him for details. I have one on the way as a matter of fact...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 04-16-2008, 09:22 AM
Thank you. Wow, talk about niche market cottage industry. Thinking ... by the time I buy that part (or rent one from a fellow PP-er), and the right bits, bolts, etc., I wonder ... does the $500 shop estimate sound about right?
And since the manifold has to come off (I assume), I'm wondering how many other bolts will break, which I am sure runs the estimate upward.
- Bob
Old 04-16-2008, 10:39 AM
you will break no bolts, IF, you heat the nut red, one at a time with a oxy/acetylene torch and remove it while it's still a dull red. bright red allen nuts tend to round out and create a removal problem, so wait a few seconds until it dulls out a bit.
206 637 4071
Old 04-16-2008, 11:03 AM
Dan in Pasadena's Avatar
Just curious, would a small MAPP gas torch be adequate for this or is an oxy/acetylene setup required to get it hot enough?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 04-16-2008, 11:15 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
No way you will get it with MAPP. I tried, but I have an East Coast Car. For the record, Christian's tool works great, is not ridiculously expensive, but the job is a PITA, especially if you're doing it on your back. But then again, I drilled them all out.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-16-2008, 03:07 PM
rbuswell's Avatar
Porsche Crest Is this blatant thread theft?
I'm going to drop the engine on my '82 SC soon to chase down some leaks and do some other cleaning and adjusting tasks and I was wondering if, given the fact that I may go to an early SSI exhaust in the near future, whether I should remove the current exhaust system and replace the studs, since the engine will be on a stand?
1982 911SC
1987 924S
Old 04-16-2008, 03:43 PM
rs6er's Avatar
I would do it while then motor is out. Certainly a lot easier to put heat on it.
John
Old 04-16-2008, 03:49 PM
AQuietBoom stud removal gizmo seems to be the cat's ass.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-16-2008, 06:42 PM
sudo apt-get purge 930
equality72521's Avatar
That's being conservative. I just used mine and drilled out 8 studs, chased and cleaned the threads, and installed 12 new studs in 4 hours with the engine in a stand. Christian's tool is effing awesome. I told my wife there are some tools that are worth every penny you spent on it and that is definitely one of them.
--clutch-monkey
Old 04-16-2008, 06:46 PM
A Quiet Boom's Avatar
Thanks for the kind words about the tool guys. I must give credit where credit is due, the original design is John Walkers, I'm just semi-mass producing them. Bob, I don't list the price of the tool on the board out of respect for Pelican Parts, PM for details.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 04-16-2008, 06:53 PM
Gents, get this: I just lifted the side of my 911 to see this broken exhaust stud for myself. What do I find? Nothing but a hole. A 33 mm deep hole to be exact.
If you look closely here, you can see threads deep inside.
Doing some research, I see a replacement exhaust stud is an M8 x 50 mm. (Pelican Part #999-062-239-02-M260)
In other words, it looks like the bolt fell OUT, and didn't break OFF as I was told by the shop.
A $5 bolt plus 5-minutes to install, instead of a $500 estimate!
Jeez, I hope the mechanic's eyes were bad, and they didn't think I was a rube (memo: don't wear an expensive watch when you take your car to a shop).
Thanks anyway for everyone's input.
- Bob
Old 04-16-2008, 08:19 PM
I used loc-tite on studs
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-16-2008, 08:42 PM
3.2 CAB's Avatar
Sounds like you dodged the bullet on that one! Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-17-2008, 10:19 AM
Thrlls's Avatar
I would still get the tool from Christian if you plan on keeping the car or doing this type of work in the future.
I used timeserts, but the next time I'll be using Christian's tool, since one now resides in my tool box.
I used anti-seize on my bolts.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 04-17-2008, 02:01 PM
Seems like no one ever mentions it but go grab a bottle of Anti-seize (Silver container - get a good sized one for $5.00) and paint those studs! If you want to know for sure you can get a bolt or nut off when you come back to it; Anti Seize is the way to go.
I painted the whole Stud/Nut assembly after I had it them tightened down for good measure - the stuff will smoke as the exhaust heats up but one of its' recommended uses is Exhaust Hardware - good to 1700F or some absurd number.
1989 Carrera 3.2L in 993 bodywork
Old 04-17-2008, 03:54 PM
