Exaust gaskets - advance auto?
Im about to replace my thermo reactors with replacement headers.. its a 2.7. Does anyone know if you can source the gaskets to the heads at a local parts store? They look common but the bolt holes might be a problem...
JP
'76 911s Ice Green Metallic bone stock
Old 12-20-2008, 05:35 AM
If you take the old one to a muffler shop, you might get lucky and find a match. I'd be surprised if you find one in the store by using the part number from Porsche.
Tony G
2000 Boxster S
Old 12-20-2008, 08:24 AM
Yeah I was hopeing someone figured out a honda equivalent or something.. dealing with the parts counter guy on stuff like this is sometimes a joke.. but every once in awhile you get some old guy who wants to find it for you.. if its a kid.. fagetaboutit.
JP
Old 12-20-2008, 09:27 AM
I put on a different muffler after installing headers and needed a new set of gaskets. I was next to Midas and went in with the old one and he found me two that were the right size and bolt hole. They had a rack of them and he just eyeballed until he found that that matched. No charge.
Tony G
2000 Boxster S
Old 12-20-2008, 10:48 AM
3.2 CAB's Avatar
About the only exhaust related gaskets that I really know about are the delta shaped, 3-bolt hole gaskets. A 2-1/2" header collector gasket fits perfectly, but... don't have a clue about the rest. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-20-2008, 01:54 PM
VFR750's Avatar
Did you look at the Pelican Site??
Amazingly, you can buy them here.....http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHpip_pg6.htm#item28
100+ in stock....
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 12-20-2008, 02:03 PM
