Rennch on YouTube
69 911 T...Rear Swaybar options.
Hey there,
My 69 T doesn't have rear swaybar mounts. Do I have any other options to install a rear swaybar other than to weld on the swaybar mounts and get aluminum trailing arms to install? I want a large, adjustable bar so I can race it...
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Mark S
No way getting around welding in a mount but no need to change or do anything to your stock 69 trailing arms if you go old style Weltmeister style adjustable SB.
Rennch on YouTube
I don't mind welding in the mounts. Does the old style Weltmeister (Which I just sold, ironically enough) just clamp on to the trailing arms?
Mark S
Nothing clamps or is done to the trailing arm or spring plate. The kit comes with eccentric bolts with a mounting studs to attach the drop links. This replaces the factory eccentric used to adjust camber.
Rennch on YouTube
That's funny. That's exactly what I just sold. Sigh...
Thanks!
Mark S
Figures don't it
. I need to correct, the threaded stud in the pic is not what the drop link attaches to, the other end is threaded female and that is what the bolt for the swivel rod ends on the drop link screws into.
IMHO, this area is one of the weak points of the rear WM bar. The threads on the eccentric bolt are merely 5/16-18, pretty marginal to carry large cornering loads. Your lighter long hood chassis may not overstress this mount though. If you can manage, try to get a set of eccentric adapters for the Tarrett rear sway bar, They used a beefier, 3/8" thread.
Sherwood |
Rennch on YouTube
Well, why wouldn't I just get a Tarret Swaybar?
Rear swaybar
Why do you need a resr swaybar on a car that oversteers? Bob
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
I used the Welty solution on my 911. Seems to be ok even if I needed to compromise due tot he location of my fuel filter. Read bout it here: adjustable sway bars...1971 chassis and here: http://forums.pelicanparts.com/porsche-911-technical-forum/326008-installing-weltmeister-rear-swaybar-clamps-post3052124.html?highlight=rear+sway#post3052124 The modified eccentric that Weltmeister makes to connect the drop links to the bar are not the greatest quality. When I installed my bar, I stripped one due to an apparent casting defect. My machine shop made a replacement to get me on the road. I believe the Tarrett ones may be better.
Rennch on YouTube
I'm in no hurry to spend any money I don't need to. Any other recommendations?
Rennch on YouTube
i think the tarret design is similar to the welt. eccentric bolt but it is an eccentric nut. the nut has a hole drilled through it off-center so it can act as an adjuster. the hole is for a through bolt that connects the drop link. very similar in design/function but because a high grade bolt is used rather than the integral stud on the welt. unit it is stronger. (i assume). i'm planning on leaving off the rear sway on my 68, if i need the sway i'll use the welt torsion tube mounts to add the sway. i think the rear sway can be small (15mm) if larger torsion bars are used. this is purely speculative however.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
As an aside, it'd be nice if the WM upper drop links used a rod end too instead of a rubber bushing. Sherwood |
Weltmeister is bad.
If you want to race, buy the WEVO ARB mounts and the smart racing bar.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Besides... even if you arent fast oversteer makes you FEEL fast.. and there is something to be said about that... (I am not joking). I think oversteer below 50 mph is wonderful thing.. the kink at road america comes to mind however.. LOL..
JP '76 911s Ice Green Metallic bone stock |
I would tend to disagree with your assessment about WM. Have you seen the Addco bars? The WM is functional, probably overpriced for what it is, but it was the only game in town for a number of years. And you know what happens when there's no competition. There are probably thousands of WM bars doing their functional job as we speak. Are there better ones? Yes, but at almost twice the price. Are there better ones for the price? I haven't seen any. With some slight revisions, the WM bar could be better than it is now. Sherwood no affiliation |
Rennch on YouTube
Thanks for the debate guys...I don't actually know what I'll do yet. I can put a stock bar on from the 72T for now. I'm running 21-27 torsion bars, and I have big tires...
