-   -   Are there any problems blending sheet metal? (http://forums.pelicanparts.com/porsche-911-technical-forum/40444-there-any-problems-blending-sheet-metal.html)
collier 05-17-2001 01:28 PM
I have a question for everyone: are there any adverse side affects to using a later bodied galvanized body panel to an earlier non-galvanized body panel.
I did not know if there would be a reaction to two dissimilar metals?
chris
chris collier
collier@iglou.com
72 911T
stock and ok with that, for now
not_sure 05-17-2001 01:38 PM
Should not be, just dont sniff the fumes when welding.
collier 05-17-2001 01:54 PM
Oh sure, take all the benefits out of it.
chris
chris collier
collier@iglou.com
72 911T
oldE 05-17-2001 02:28 PM
Chris,
The metals are not dissimilar. Galvanizing refers to a layer or coating of zinc which is applied to the steel (usually by "hot dipping" it into a vat of molten zinc) Unlike untreated steel which rapidly oxidizes until it is all gone, the zinc forms a coating of zinc oxide on its surface which prevents further oxidation from occuring, thereby protecting the steel underneath.
Too bad it wasn't part of the Old E.
Les
