sbrown.nw's Avatar
changing bolt pattern with adapter spacers
Hey all,
I have a 72 with 85 body parts and other internals. I was thinking about new rims and either going with some classic Rota Foxes or going with these adapter spacers that will change the bolt pattern to a more common 5x4.5 pattern like
these.
Has anyone used these before? What offsets and widths did you go with in the front and back?
Thanks,
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 04-20-2008, 04:24 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
hmmmm, i'm really trying to find something wrong with these.... Cant see much difference between these and the regular spacers.
Also, the ones at the bottom are spacers, not 'adapters'.
Old 04-20-2008, 06:47 PM
MarKoBrow's Avatar
These look great, maybe now I can mount my American Racing Torq thrust wheels on one of my cars....cool, good find
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 04-21-2008, 04:58 AM
ttweed's Avatar
Just be aware that if you want to run in performance driving events, changing the Porsche bolt pattern with adapters is prohibited by the rules of many race organizations. In PCA Zone 8, you could not even autox with those adapters.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-21-2008, 06:55 AM
Crotchety Old Bastard
RarlyL8's Avatar
Adapters for 130mm to brand x are no different than adapters for 130mm to 130mm where safety is concerned. The stock Porsche configuration uses spacers and long studs, that is the distiction. 5 lug nuts and studs/wheel for spacers vs 10/wheel for adapters.
I have adapters that went the other direction, from 5x4.5 to 5x130mm, so I could run Fuchs on a different vehicle. Adapters are a PITA (changing a flat using the non-Porsche spare) but the only alternative is to re-drill your hubs for the new pattern. I didn't want to do that!
Old 04-21-2008, 07:20 AM
sbrown.nw's Avatar
So, to double-check my math with people that have put later model rims (964, 993) on earlier model Carrera and SC cars, I see the following specs listed for Fuch wheels:
size: 8x16 offset: 10.6mm (911) - front
size: 9x16 offset: 15.0mm (911) - rear
Since the adapters are 31mm thick, it looks like I would need to order rims in the following sizes:
size: 8x17 offset: ~42mm - front
size: 9x17 offset: ~46mm - rear
Does this look correct? I don't want to have to roll any fenders or have any rubbing issues so if anyone has any recommended adjustments to the numbers above, I would appreciate it. It looks like the front I have a little room to play with because the 951 8x16 Fuch will fit up there and that has a 23.3mm offset.
Thanks,
Scott
Old 04-21-2008, 03:24 PM
Originally Posted by white78911 View Post
Hey all,
these.
Thanks,
Scott
Scott,
Thanks for the link. I've been looking for these for a long time and just ordered a set 5 mins. ago.
Great price too!
Thanks,
Joe
74 911 w/ 86 3.2
Old 04-21-2008, 06:43 PM
Send a message via Yahoo to Lukesportsman
Tom's statement above is the only factor to really weigh in on this in reality. Porsche's 14mm bolts on a 130mm circle is/was overkill, but that's so much nicer than the opposite with Mustangs running on 4 12mm studs.
PCA will not allow you to switch bolt patterns. I guess that's unless your upgrading a 914 to another "superior" Porsche bolt pattern. I don't know how the 356's keep their wheels from just falling off!!!!! Oh well, that's the rule book.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 04-21-2008, 08:30 PM
