door gaps
Replaced right door on my 76 with an 86 and the gap on the rear edge without
shims is 1mm and have no adjustment left. What methods are there to adjust
the gap. Thanks for any help.
Old 04-20-2008, 05:52 PM
I have two Porsche books that both offer a method to increase the rear gap, but I've never done it. The described method is to remove the door, but leave the hinges on the door post. Then, with a block of wood and a 5lb. single jack (sledge hammer), strike the edge of the hinges (where the pin goes) to move them slightly toward the front of the car. Sounds scary and certainly not precision, but that may be the way to go.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-20-2008, 06:28 PM
abit off center
cgarr's Avatar
I have done this also and you can drive the hinge on the door in and pull it out also if needed, but make sure you have good bushings in the hinges first so your not fighting any sag. They may have used some body solder on the door edge at the factory on that 86 door and this may have to be taken off to get the correct gap.
______________________
Craig
G2Performance
Old 04-20-2008, 07:09 PM
The factory guys used hammers of varrying sizes -- and they had some pretty big ones for just this situation -- for all sorts of fitting tasks. I'd hesitate to do it as well but this is the first vehicle I've ever owned that did not have easily adjustable doors.
1989 Carrera 3.2L in 993 bodywork
Old 04-20-2008, 07:19 PM
3.2 CAB's Avatar
There is actually a TSB on this subject that does give a little bit of info about the BFH method.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-20-2008, 08:49 PM
Stressed Member
Scott Clarke's Avatar
How can one access the "TSB"?
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 04-21-2008, 07:42 AM
