SC Ignition Wire Impedance
My SC Motor is misfiring.
I just put it back in the car after the winter projects. I refurbed the stainless shields of the wires and put thick shrink wrap over the spark end where the wire enters the plug holder Had sparking to engine issues last year. I measured the impedance from the distributor end right to where the spark plug touches They all measures between .98 and .95 when the meter was set to 200K Ohms. Can someone explain what this really means as the threads I have found say it should be higher.
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
Bump
Sparking to engine issues will not be fixed by refurbing the stainless shields. Sounds like you need new wires. It is also possible you still don't have a good connection onto the spark plugs. This can be tricky to get right.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
+1 on the wires
1981 SC Targa Euro - Minerva Blue 2003 Audi A4 1.4T 1999 Audi A4 1.4T - Hers |
From personal experience, save some time and frustration and invest in new wires. You will then have a base line on a solid ignition system that you will not have to worry about for a few years.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
The wires them self has almost no resistance at all, but the spark caps has a resistor that can fail. It's pretty much always the caps, not the wire, that fails.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
It's typically the connectors that fail, especially Beru which should have a resistance of 3Kohms but often will short out under heat or vibration.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 05-18-2009 at 10:58 AM.. |
Somatic Negative Optimist
To be clear:
Stock SC ignition harness with braided steel has Beru connectors on both ends. The cap-end has a short one with ~1k OHMS. The plug-end has a long one with ~3k OHMS. The wires have no resistance. To test, check each wire with connectors in place with a DIGITAL, not Analog, multi-meter end-to-end to get ~4000 OHMS total. Any different result requires the connectors to be checked individually; simple and easy. Berus are alright if you check the resistance once a year. I have new non-braided 8mm wires with Beru each end. ![]() John, get new wires and if you need to replace some connectors, advertise for some used Berus on PP "For sale and wanted" And try a lower test-setting than 200K.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Gunter
I am a little confused on the dist cap end I have the little rubber shield and then a smal copper unit with a nipple that is soldered to the wire exiting the cable. When I did my testing I probed from the nipple to the metal piece inside the connector that snaps around the top of the spark plug. Was this the correct method? and What would you suggest next if not? Thanks
Take one complete single wire off and post a picture so we can see the end-connectors and how the wires connect into them. You may not have Beru and may not have any resistance in the connectors which is alright providing the wires are in good shape and the long plug connectors don't allow arcing (grounding) into the case.
Will do
thanks
Here are some picks from my phone.
