I'm still the only one with the 'fly' (or is it sic?) LED license plate lights though... I know, envy of everyone.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Member 911 Anonymous
I'm Green with Envy
.BTW, what type of bulb goes in there?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
The Puff.
Can we see pics of your LED's in the day?
'70 CT1B '11 GTS 300 Super |
I don't remember, but they are now customized by me. It wasn't plug and play. If you remember, look at them Saturday.
In Day Light:
Brake Lights Off ![]() Brake Lights On ![]() I thinks I need to use my Digital Camera, the cell is not that great, can't even see my third brake light
The Puff.
:P Yeah, the pics are too blurry to tell.
1-6-2-4-3-5-1-6-2-4-3-...
You'll just have to hope that the lady following in that SUV doesn't have sight as blurry as that
'70 911E Coupe, Webers 40IDA |
RS 73
here is another source of LEDs that I used for my 73. www.v-leds.com
I found them on eBay, but they have this site as well. Their brake lights are very bright. Another interesting product is the resistors for the directional lights. With a pair of these you do not have to change your flasher. Just build the resistors into the rear housing. You use these ONLY on the directional lights! and just need one set per circuit left and right. I wish I had seen this post before. I did essentially the same thing, but sort of made it up as I went along. I found a set of LEDs at a truck stop and that got me thinking. I had the car apart for paint anyway and I had one side market light not working and I knew the rest we dodgy at best. I kept the original sockets and just fixed them up. Next time i may just do away with them and make the conversion electrically more solid. By the way V-Leds also has some cool Xenon v-Hid kits for headlights....
Dick Lague RGruppe #79 1973 RS Spec Carrera 2001 Saab 95 Aero 2003 Saab 95 Aero Last edited by dlague; 08-08-2008 at 09:13 AM.. |
Anthony Vanderlinden ---------------------------- 1987 Porsche 911 1979 BMW 635Csi Euro 1926 FN 1300 |
I know this is an old thread.. but I think a capacitor is what you want here.. Im not sure of the value.
JP '76 911s Ice Green Metallic bone stock |
Well, my tail light housing won't hold the bulbs tightly so i was thinking about replacing the holder part. I saw superbrightleds.com has the ba15 wired sockets so has anybody tried them in the 911 housing?
'82 911 SC track car - SOLD '86 944 NA - SOLD '01 Boxster S |
No. Not unless those behind you have the visual acuity of an owl or other bird of prey. The IP bulbs are quite dim relative to regular DOT-spec bulbs. Have you tried pulling the bottom contact of the socket outward a little? Some have tried depositing solder around the bulb base to increase the OD slightly. Sherwood |
Reviving an old thread...
I'd like to convert my 81 930 to LEDs - at least for the signals and brakes. Should be identical to a 911SC in this respect. According to the schematics, these cars use a 4 pin flasher relay. See: http://www.pelicanparts.com/911/911_parts/Electrical/911_electrical_78SC_USA.pdf The extra pin seems to be required for the indicator lamps in the dash. So I don't see how a 3 pin flasher can work without rewiring. Has anyone found a decent source for the electronic flasher relay? Or... How did you get it going with a 3 pin relay? |
Nobody? Anybody?
Okay... Comparing the schematics from an 1981 to an 1985... On the '81, the dash indicator bulbs are tied to pin C on the flasher module - presumable so they can indicate some sort of failure? On the '85, the C pin is not used and the dash indicator bulbs just go to ground... So... I presume I can just reroute the lead from pin C to ground and use a regular 3 pin european flasher module? Here goes... |
Geez, hard to say, I don't think anyone has done this, just take care, and let us know the results.
We assume you have some electrical back-ground to attempt this task, right?
