ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Question Front bilstein inserts won't come out
Ive done this a million times before, I have the roll pin tapped out, I have the o-ring removed.. this crap refuses to come out. anybody have any tricks?
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 04-26-2008, 09:08 AM
syncroid's Avatar
Hey Todd, It sounds like you have a bent strut. You can get the old insert out with a big slide hammer but chances are that you won't be able to get the new insert back in.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 04-26-2008, 09:14 AM
syncroid's Avatar
One more thing I just thought of, if they are Bilstein struts, make sure that you vacuum all the rubber bits out of the strut housing before you try to reinstall the new inserts.
Dan
Old 04-26-2008, 09:15 AM
ToddM's Avatar
Okay, I figured it out, i screwed it back into the top mount and jumped up and down on the caliper - POP
Thanks guys
-Todd
Old 04-26-2008, 09:25 AM
ToddM's Avatar
Anybody have the part number for the insert sealing ring?
-Todd
Old 04-26-2008, 09:30 AM
abit off center
cgarr's Avatar
Are you talking about the top dust seal? 46mm OD one? Are you replacing the bushings too?
______________________
Craig
G2Performance
Old 04-26-2008, 10:16 AM
ToddM's Avatar
its a hard ruber o-ring thatgoes around the insert and holds it inside the strut tube
-Todd
Old 04-26-2008, 11:29 AM
mca mca is offline
mca's Avatar
Remove Strut Insert - Try This If Insert Is Stuck
FWIW ... I had same problem. Posted the above thread. May help someone down the road.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 04-26-2008, 12:31 PM
ToddM's Avatar
Ok what gives, countless timem before Ive replaced strut insert with ZERO problems
Now I got one side donea and the strut nut on the other side is so attached Im just spinning the strut as i turn the nut.
Wish I had a torch !!!!!
-Todd
Old 04-26-2008, 12:40 PM
mca mca is offline
mca's Avatar
Dont you have to counter hold the large nut with a pipe wrench while loosening the insert nut?
Otherwise the strut will spin ... or am I missing something here?
Old 04-26-2008, 12:43 PM
You should be able to hold the strut rod a number of ways including using a large pipe wrench or a vice grip on the rod or threaded portion of the junk insert.
Old 04-26-2008, 12:44 PM
ToddM's Avatar
I dont want to damage the tube... I was planning on getting the insert revalved but this one is not comming of so maybe i'll attack it from the top threads.
almost more trouble than its worth
-Todd
Old 04-26-2008, 01:23 PM
mca mca is offline
mca's Avatar
Todd -
If you can't get the insert out, take a look at my post above where I included a link to a thread.
It is really easy to go to Lowes and buy those pipe fittings - and they are cheap cheap cheap.
Place fittings over insert and they will rest on the strut housing. Then place the large washer and nut on top of the insert and start tightening it down. It will EASILY pull the insert out of the housing.
Trust me, I fought mine for 4 hours and finally decided to go to Lowes (I hate going there on weekends - was beeing stubborn).
Old 04-26-2008, 01:28 PM
ToddM's Avatar
Originally Posted by mca View Post
Todd -
Yeah i got the insert out by simply threading it back on tot he top plate, then standing/bouncing on the brake caliper until it popped.
now the other instert, the top nut is stuck
i think ive never spend anythin more an an hour and ahalf doing this.. this one ive spent 3 hours on and right now i put it all back together.. i dont need the car jacked up or the wheel off to keep attempting to break that top nut
-Todd
Old 04-26-2008, 02:21 PM
ToddM's Avatar
of course i did the obligatory smash yer thumb with the hammer when inserting the roll pin
-Todd
Old 04-26-2008, 02:31 PM
ToddM's Avatar
Hey DH; I didn't realize that was you
The tp 3.4 gave it away
-Todd
Old 04-26-2008, 03:43 PM
