-   -   Bouncing speedo (http://forums.pelicanparts.com/porsche-911-technical-forum/406369-bouncing-speedo.html)
equality72521 04-28-2008 07:11 AM
Am I the only one not seeing a post here???
equality72521 04-28-2008 07:12 AM
Ok, this is weird. ossiblue created a thread about a bouncing speedo but there is no post.
ossiblue 04-28-2008 06:05 PM
Yea, weird! I posted this morning and never had a chance to log on again, then I find nothing appeared! Well here it is:
The speedo on my 73 has a bounce at nearly all speeds until I exceed 120 mph;). Is there any easy way to tell if the problem is in the cable or in the gauge itself?
Sam 69 Gulf 04-29-2008 05:49 AM
I just had my (69) Speedo rebuilt to cure an odometer issue. When I reassembled I got terrible bounce. I replaced and removed the cable a few times trying to make sure it was as untwisted as possible and routed with nice wide curves. Third time was a charm and the bounce was cured. I am not an expert but after disassembling mine I cannot think of obvious mechanisms inside the speedo that would cause it to bounce....
ossiblue 04-29-2008 01:42 PM
Thanks Sam, that sounds reasonable. I just got the car and I don't know how old the cable is and given you have seen the "workings" of the speedo, I'll try the cable cure first.
