plano25
Guest
Posts: n/a
Angry Sunroof won't close!
Help! The other day I was driving my car home and the sunfoof would not close all the way. It will close halfway and then stop. The motor seems to work fine but something is going on in there preventing it from closing.
What do you think?
Donald Weintraub
1980 Porsche Red 911SC Coupe
Old 05-22-2001, 05:29 AM
john walker's workshop
Guest
Posts: n/a
Post
probably one of the cables broke, binding the panel. you can pull it on the side that's lagging behind, as you work the switch. make sure the rear of the panel doesn't raise up early and scratch the paint. then help push up the rear from underneath to close it.
Old 05-22-2001, 08:49 AM
rstoll
Guest
Posts: n/a
Post
Might try cleaning the rails that the roof runs in. I changed cables the other day and cleaned the rails. There is a kind of clutch on the drive motor, if the rails are dirty it could be slipping.
Robert Stoll
83 SC
83 944
Old 05-22-2001, 09:19 AM
Ronbo
Guest
Posts: n/a
Post
When this happened to me, it turned out to be the plastic "clips" which hold the air deflector to the sunroof rails. They were cheap and easy to replace.
Ron
'88 Coupe
Old 05-22-2001, 04:55 PM
Ronbo
Guest
Posts: n/a
Post
Ron
'88 Coupe
Old 05-22-2001, 04:56 PM
83 sc euro cab
Guest
Posts: n/a
Post
I found this on Pelican Parts. Hope it is helpful
http://www.pelicanparts.com/techarticles/911_sunroof_repair/911_sunroof_repair.htm
83 sc euro cab
Old 05-22-2001, 07:07 PM
ckrause
Guest
Posts: n/a
Thumbs up
Don-
I recently had the same think happen in my '73T. I followed the Pelican article relubed the cables and anywhere necessary and it works like a charm.
-CKrause
Old 05-22-2001, 07:48 PM
Malcolmh
Guest
Posts: n/a
Post
Ronbo...where did you get the plastic clips from?
Old 05-22-2001, 11:58 PM
Ronbo
Guest
Posts: n/a
Post
I bought the clips from my local Porsche dealer. I don't remember the cost, but it was very low.
Ron
'88 Coupe
Old 05-23-2001, 04:38 PM
Ronbo
Guest
Posts: n/a
Post
Ron
'88 Coupe
Old 05-23-2001, 04:39 PM
Ronbo
Guest
Posts: n/a
Post
Ron
'88 Coupe
