still trying to determine exact caliper
We are still trying to determine the exact caplipers that have been put on the rear of the 914-6. We know they are not the original rears.
We thought they were 84-89 carrera fronts. Things just don't seem to match up. Specs once again. They have a 3" odc bolt spacings ("M" calipers) They have 42mm pistons ("A" calipers) They have a 14mm spacer ("A" calipers) They fit on a 24mm rotor utilizing a spacer to center the caliper on the rotor They have pads that are 61.25mm wide X 44mm tall. (pad area only) The pad pin spaceing is 45mm odc They are single bleeder cast iron. Everything I have read on Bill Verbergs site has different pad sizes. A definitive answer would sure help in ordering pad. It took us three rebuild kits to get one that would finally work. |
they are wide M, from the back of an '84 - 89 Carrera
this is the pad, except for warning sensor notch http://forums.pelicanparts.com/uploa...1209468359.jpg |
Thanks Bill for the answer. The drawing helped. Perhaps if Pelican has a brake wiki they could include the pad drawings for each of the calipers as another method of identification. In combo with the other information.
| All times are GMT -8. The time now is 11:59 PM. |
