911 SC fuel pump flow capacity?
How much fuel can the stock pump in my 1979 911 SC flow?
FP Flowrate.......
I know very little about the CIS system, I am converting to EFI along with other changes I will post about later. I was wondering what the basic volumetric flow rate the pump is rated for. Also if the pressure spec, line size, and applied voltage at said flow rate is known that would be appreciated as well.
