Milo2361's Avatar
Just noticed this - - wheels.....
Noticed today that my rear wheels slant inwards a little..... closer in at the top than at the bottom? (like this -as if looking at the rear of the car..../....\.... just not that dramatic) Is this bad? upon inspecting the tires I discovered the treadwear is uneven (inside being more bald than outside), but there are no bumps, just a smooth wear.
Is this a suspension problem? what should i do?
Thanks in advance ! you guys are great
1998.5 Ram 2500 Cummins
Old 04-29-2008, 06:23 AM
Milo2361's Avatar
Ahh crap totally posted this in the wrong forum any way to move it to the 911 tech forum? lol sorry bout that
Old 04-29-2008, 06:27 AM
Less brakes, more gas!
euro911sc's Avatar
Its called negative camber and it is a good thing to a point. Too much and you get uneven wear when driving on the street. Not enough and you loose grip. It is a compensation for changes in geometry when you corner the car. Most of us like lots of it and to hell with buying new tires
And yes... this belongs in the 911 forum
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-29-2008, 08:31 AM
Milo,
Just like the front end, the rear has alignment adjustments for camber and toe.
For your use, looks like one or both need adjustment.
Racers usually run negative camber front and rear for better traction.
A race alignment doesn't wear well for street use.
This isn't a big deal for a decent alignment shop.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 04-29-2008, 10:25 AM
abit off center
cgarr's Avatar
Its ok as long as its not that way because of rust
______________________
Craig
G2Performance
Old 04-29-2008, 11:19 AM
Milo2361's Avatar
good idea or bad idea - -- - use the fix it book and do it myself?(that is if it has this type of thing in it) don't feel like i should have to take it to a shop..... and i feel i should get to know her underside a little better..... - - i'll probably get new tires before i head off for college anyway - - these ones are starting to get a little old... or worn....
Old 04-29-2008, 07:35 PM
