-   -   Placing an order.. What am I missing? (http://forums.pelicanparts.com/porsche-911-technical-forum/406685-placing-order-what-am-i-missing.html)
davis911s 04-29-2008 04:10 PM
Ok I am placing an order for my car. Basic tune up stuff, the car has sat for 4.5 years and I will be getting it back on the road in the next few weeks.
Here is what I ordered
Fuel Filter
Oil Filter
Air Filter
New CIS airbox straps (cheapo's)
NGK Spark Plugs
Distributor cap
Rotor
Pertronix (replacing my points)
2 Oil drain plug seals
Alternator belt
Valve feeler gauge and spare blades
SILICONE valve gasket with new nuts and washers
First off can anyone think of something else I NEED? Secondly are the Silicone gaskets worth the little extra money?
Thanks guys I will be placing the order thursday, I just want to make one order and not miss something and it has been a few years since I tinkered.
Shawn
Medicine Hat, Alberta, Canada
Jesset100 04-29-2008 04:25 PM
Spark plug wires
brake rebuild kit
brake fluid, pads, flex lines and maybe new rotors
dfink 04-29-2008 04:42 PM
As long as you are doing all that you might want to change the tranny fluid with swepco 201. Also after that long brake fluid to bleed the brakes.
Icemaster 04-29-2008 04:47 PM
Originally Posted by Jesset100 (Post 3915152)
Spark plug wires
brake rebuild kit
I was thinking exactly the same thing. At the very least, check the pads and replace the fluid.
Before you get the car running, make sure you can stop.
