cds72911
Guest
Posts: n/a
Post Removing aluminum door trim
I just searched the archives and didn't find anything.
Does anyone know how to remove the aluminum trim from the top of the doors? It looks like they may just be pressed on, but I do not want to damage them during removal, so I thought I'd ask first.
Thanks,
Charlie
'72 911 T
Old 05-24-2001, 06:50 AM
Allan Broadribb
Guest
Posts: n/a
Post
It's just pressed in. When I removed mine there were plastic clips on the back of the strip. They should be reusable but I ordered replacements from Pelican which are metal.
Allan Broadribb
'70-911E, 2.2l with Webers
http://www.cheaterswayside.com/uploads/Mvc-002s355.jpg
Old 05-24-2001, 07:18 AM
zotman72
Guest
Posts: n/a
Post
The trim is snapped down with plastic
expansion pins. You have to get under
the trim adjacent to the pin location and
gently pry up. A putty knife works. Lining
up the pins to reassemble is a little tricky.
The pins slide on the trim.
HTH
Bill
72T
Old 05-24-2001, 07:20 AM
campbellcj
Guest
Posts: n/a
Post
If yours is not too "stuck" you can sometimes also slide the whole strip carefully so one edge hangs over the edge of the door, and then lift up on that.
Be careful as it is very easy to damage your paint while working with these fairly large trim pieces!
Old 05-24-2001, 10:18 AM
cds72911
Guest
Posts: n/a
Post
Thanks everyone!
I'll try removing them tonight. I'm not worried about ruining paint, although others may need to be more careful (my car is being stripped to bare metal for paint).
Charlie
Old 05-24-2001, 10:40 AM
radcon
Guest
Posts: n/a
Post
If you are going to use a putty knife or some other tool to pry up the trim, place a couple layers of masking tape along the door first. That way you won't scuff the paint. Good luck
'80 Targa
Old 05-24-2001, 10:53 AM
Roland Kunz
Guest
Posts: n/a
Post
Hello
They are fixed with some ( 7 ) clamps normaly you lift up one end and brake loose each clamp.
Those clamps are very simple and reusable. But on the early cars made from NLA plastic. Later cars had steel and this is no problem ( Well they do rust )
Grüsse
Old 05-24-2001, 12:34 PM
