-   -   Anyone modified an old CAT (http://forums.pelicanparts.com/porsche-911-technical-forum/406909-anyone-modified-old-cat.html)
dgraves 04-30-2008 08:26 PM
1) Can you disable an old CAT without any negative impact?
2) Is there any significant noise impact when replacing CAT with by-pass pipes?
Thanks,
Dan
equality72521 04-30-2008 08:32 PM
Here's a guy who just put a cat bypass in:
http://forums.pelicanparts.com/porsche-911-technical-forum/406829-i-lost-21-pounds-but-my-neighbors-gonna-pissed.html
oregonmon 04-30-2008 08:41 PM
I just did that. The difference in weight (Bursch bypass) is about 7lbs. I did notice a bit more torque around 3500rpm with the bypass and stock muffler. Sound was basically the same. Check the thread from the previous post for feedback with a cat/muffler bypass setup that I will be finishing tomorrow. Looking for my earplugs now.
You could have the old cat punched out too. Basically the same as the bypass without the weight loss I would think.
EarlyPorsche 04-30-2008 08:52 PM
Really? Taking off a Cat typically reduces torque because you lose "good" backpressure.
oregonmon 04-30-2008 09:51 PM
I think with the stock heat exchangers, which are supposed to be the more restrictive part of the exhaust system there is back pressure. Again, I am no expert.
Dixie 05-01-2008 04:04 AM
If your old cat is plugged, you can empty it out. The interior is three ceramic "bricks". All you need is a steel rod, a hammer, a vacuum, and time.
If your cat is good, you'd be better served to buy a bypass pipe and save your converter for reinstallation later.
