another mixture question
Hey guys. Im thinking of buying a fuel/air mixture monitor like this.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EDL%2D6593&N=700+ 115&autoview=sku The ranges are from 12.1 to 15.1 What should a 3.0L CIS be set at? |
mack6820,
I would have difficulty 'reading' the LED portion. If you are looking for other options or opinions... I installed a Westach A/F monitor and absolutely love it. Since my SC is controlled by Lambda, it averages out to a 14.7 A/F ratio during normal cruising. This gauge has really earned its keep. I have never seen the need nor added expense of adding a wide-band sensor. The other gauge in the photo below is CHT with a selector switch for the left and right bank. http://forums.pelicanparts.com/uploa...1209686992.jpg |
Thats a nice setup there. I'll do the research. Thanks
| All times are GMT -8. The time now is 09:24 AM. |
