jevose
Guest
Posts: n/a
Question 88 930 Valve adjustment??
Anyone every done a 930 Valve adjusment. Any big differences from a normal 911??
Jim
jevose
82 911 SC
88 930 Turbo
Old 05-25-2001, 10:47 AM
5axis
Guest
Posts: n/a
Lightbulb
Engine drop. No fkn around and makes it easy to see exactly what you are doing. This is also a great time to clean the engine and compartment, R&R any stuff on the motor itself and install and more gofast goodies. I suppose you could remove enough crap to be able to see the valve covers but why fight it. I spent a relaxing weekend doing mine, next time it should go quicker and easier. This is the price we pay to be way cooler than than the NA guys and worth every penny($$$$)
good luck
david 89 turbo cab
Old 05-25-2001, 11:10 AM
john walker's workshop
Guest
Posts: n/a
Post
when i worked at the dealer in the 70s, they liked you to lower the engine to do the valve adjust, but after a fire caused by stressed fuel lines, when someone lowered it too far, they quit doing it that way. if you pull off the air pump crap, (leave the pump on),and the curved rubber intake hose to the sensor plate housing, you can get at the plugs, and get the cover off. the adjustment is tough with two hands, but with a little patience, you will learn to do it one handed. no fooling. the right side is no harder than a normal 911. just get the AC unit out of the way.
Old 05-25-2001, 01:41 PM
