Make Bruins Great Again
How do you fix a horn?
One of the horn trumpets doesn't work. (This is not a problem with the horn button, relay or wire connectors).
I remembered a post where someone said that you can take the horn apart a fix it. Well, I took it apart but can't find anything that looks bad. I've just finished searching and can't find the repair info. Anyone remember where it was or know what I can fix inside the horn itself.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
did you try hooking the horn up directly to a battery (using any wire, i used speaker wire) to confirm they were in fact blown?
2007 997 TT 1992 500e |
I replaced the short horn with another one and it works but I would like to see if I can fix the old one.
Anyone remember?
I remember buying a set of used horns from Oklahoma Foreign. That fixed it.
Try hooking the horn up directly to the battery w/ some wires.
If it doesn't work, reverse the wires and see if that does it. did for me. |
Sometimes a shot of oil/wd40 will bring them back to life.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
