What could this Temp Gauge Electrical Gremlin be?
After the 930 warms up, the temperature gauge starts climbing higher than it is running, especially after running a while. This has a new numeric gauge & sending unit. I know it is not running at 250, because when I hit the window switch it will fluctuate the temperature. Also after it is turned off & turned to the on position it reads usually about 212 degrees. What could be causing the jump in harmony with the window switches? Ideas?
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 05-04-2008, 07:27 PM
