toddu's Avatar
Wheel spacers - need a little more room
I believe I've got 1/2 (15mm) wheel spacers on my car now. I get some rubbing on the inside of the wheel well near the trunk from time to time. Figure I'd but the stance out a bit. Problem is, it seems like everything the next size up requires the adapter to be bolted to the hub (so adapter, not spacer). I just got and installed longer wheel studs because the 1/2 spacers the PO put on didn't give enough bite.
I hate to now pound those out, and bolt more stuff on.
Any advice???
Todd
'81 SC
Old 05-06-2008, 05:44 PM
DUK DUK is offline
DUK's Avatar
Sounds more like the front tires are turning too far. Or you've put on wider front tires and so are having this problem. I believe someone makes a steering limiter to go on your tierod to fix this. Hope this helps.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSstr_pg3.htm#item12
Just noticed this was my 1000 post, yea!
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 05-06-2008, 07:57 PM
