Cup Wheel Lug Nut Removal
Did a search... did not come up with anything.
I have cup wheels... I needed to take a wheel off and grabbed my 24mm soft socket that I used to use on my Fuchs.... would not fit in the hole, too thick !! I had three other 24mm sockets... nothing would fit in !!! What do I use ??? Where do I get it ?? Thanks, Chuck |
try a 19mm.
Even if the proper 19 mm socket is too thick.....look for an appropriate ( if 19 mm is correct, as I suspect is correct) stamped steel version that may be used for lawn mower plug removal, and such..... smaller OD ....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Non Compos Mentis
You need a 19mm "Thin Wall" socket. They are readily available.
