3.2 idle control valve go bad
Last summer I got some problems with my 3.2 idle control valve....(see thread below)...After cleaned it, it working very well for some time. Now the problem is back...I cleaned it again...and all is OK again. Question is: what cause the ICV to get dirty to the point I have to remove and clean it regularly....Thanks for the imput...!
http://forums.pelicanparts.com/porsche-911-technical-forum/370635-carrera-3-2-idle-fluctuation.html |
1. Dirty or torn air filter? (allows more dirt and oil vapour to get thru)
2. ICV just old and beginning to fail? 3. You mentioned you lubed it after cleaning... just clean it w/ carb cleaner and let it dry. Don't want or need an oil film on it. 4. gremlins. |
maybe it's the electrical contacts, and removing it and reinstalling re establishes the connection? I dunno, I'm reaching here.
I'd think about getting a new one and keeping the old as a spare if it happens again |
Yup....look like I'll need to buy a new one...Thanks for the imput guys.
I too removed and cleaned my ICV last year with success. I didn't disassemble it just blasted carb cleaner and shook it around for a bit until I heard the rattling noise. This year I had another stalling problem so I purchased and put in a new ICV. Problem solved. Prior to installation I noticed when shaking the new valve and comparing to the old the rattle was similar. I'd read this was one way to determine if the valve was clogged. So I decided to take apart the old valve and examine. Not sure what I'm would be looking for but I did notice the top shaft / barrel is extremely galled up. Is this normal? Just doesn't seem like the small copper contacts in the valve cover would easily cause this. http://forums.pelicanparts.com/uploa...1210008502.jpg
How does the throttle body look? is it as dirty as the ICV? I'd suspect it should be. And if it is then you have oil in the intake and the only way I know oil can get into the intake is via this breather pipe. My 84 Carrera is extremely clean in the intake and stays this way all the time. I suspect the issue has to do with oil getting into the intake via this pipe. Does the engine have poor leak-down or compression? Just a few things to think about. |
On the back of this 90deg rubber boot is the pipe from the oil filler neck and on the front of the boot is the intake pipe to the ICV. This is why it's a straight shot across the inside of the boot for the oil tank fumes to go straight into the ICV input pipe. Hope this makes sence. |
Here's a picture to help locate the pipe from the top of the oil filler neck to the back of the 90deg rubber boot:
http://forums.pelicanparts.com/uploa...1210084022.jpg |
Sory Sal...I was thinking about the pipe that goes to the air box...I will check this line tonight and will give you feedback on my find.Thanks a lot for the info.
If the ICV has oil in it this pipe is the most likely source. Since it feeds directly into the same rubber boot that the ICV input pipe is also connected to. The important thing to check is the pipe at the end that connect to the oil filler neck, inside this end you should find a brass funnel. Be sure it's there and also that it's installed correctly and has not somehow gotten crossed up. Also inspect the inside of the pipe in general to see how oily it is as well. Keep in mind that as the engine ages and compresion drops it tends to pressurize the oil system and more oil/fumes are collected via this pipe. |
Ingo |
ischmitz
The galling appears (to me) too deep to polish out. I'd probably have to take down 0.02 - 0.025 worth of material which I would imagine would negatively effect the operation. I was just wondering if those who have taken these valves apart have seen the same condition. I might do it anyway since the old valve isn't needed now.
thanks |
You may find this thread of intrest, it's howto bench test the ICV. I did this work about a year ago: http://forums.pelicanparts.com/porsche-911-technical-forum/360766-bench-testing-carrera-idle-control-valve.html |
regarding the ICV getting gunked up... I think this may have been mentioned.... the crank case vent is across the way from the ICV pickup.. all sorts of oil fumes and even oil can come down and then across there...some goes across and goes through the ICV gunking it up. If you take off the MAF sensor and big black boot/etc. and then take off the throttle body... you will probably see a good amount of "soot" on the walls. This is the soot that gunks up the ICV... that's my theory anyway. I thought hey... it shoud be nice and clean in here... but it's not.
Cool... I was wondering how those worked. Are there two wires going to those slip rings from the rotor? Does each slip ring cover 180 degrees? Where does the third wire go (+12v)?
That galling may be metal transfer from arcing. Quote:
the center wire is 12v the two outside contacts are grounds for the two "poles".
it works like two motors.... when one side is grounded the valve flips closed when the other grounded the valve flips open.... there is a PWM driver in the ECU that decides how much time should the valve be open or closed depending on the idle speed. by looking at your contact.. seems like you should get a new ICV...I'm not real sure why this started arcing.. most likely the contact in the body got worn out.. others may know more about this... |
the valve has two modes
1- turning one way - one side is grounded and the other ground is open - current flows from the center (12v) to the one ground 2 - turning the other way - the other side is grounded and the previous ground is lifted - current flows from the center to the now other ground so it sort of acts like two small independent motors... very German, everyone else in the world uses a solenoid - cheaper and more reliable - but no we got to use lots of parts, we like having lots of parts - the more parts the more money we make or something like that or Dieter used that 25 years ago and it worked.. so we keep doing it. That being said the 3.2 ICV does seem to be fairly reliable... minor compared to the valve guides going out. |
Then the outer 2 pins are the ones that get grounded and these get wired to the top (the one in the pic that has the arc damage) if you look at this top section you will see it is split into 2 halfs, one half is for each outer pin. Then the motor is wound with 2 side by side windings, electrically it is like to seprate motor windings on one axel. So at one end (bottom) the 2 widings tie together to 12V and on the other end (top) each wire has it's own contact point that goes to the outer pins. Hope this makes sence. |
Does +12 make contact through a slip ring or is it just a wire? |
I don't recall 100% but I do know the 12V center pin does not make contact via that 2 part split section that has the arcing, that section is for the 2 outer pins. The +12V makes contact in one of 2 places: the top shaft it self, right above that arced section - or - at the other end of the motor. It's been 9months since I had mine apart and I did not take pictures. |
ICV - replace or clean?
I just had my car serviced and replaced DME, Crankshaft Sensors, new shocks, tires, etc.
My mechanic also believes I should replace my ICV - as my idle is a bit rough when cold and a bit variable when warm. He suggests I buy a new one - as it is original (1984) - like pretty much everything else on the car... Is cleaning a viable option / first step? What are the odds that I will damage the sensor - i.e. need a spare on hand OR be out of commission? Also will I need to make any adjustments after I clean or replace the unit? Thanks - jcsjcs |
I'd clean it. There is no danger of damaging it. Use break cleaner or carburator cleaner. To check if it is working properly ypu can remove the ICV and disconnect both rubber hoses.
Then hook up the electrical connector, switch the ignition to ON (don't start the engine) and look into the tube of the ICV holding it in your hand. It should vibrate (80 Hz) and you should see the internal valve thingy jerking a little bit about every 3 to 5 seconds. If it does that it should be fine. ingo |
FYI - I cleaned mine last night. Took it out and soaked the "valve" end in Brake Cleaner for a few hours. Seemed to loosen up a bit. When I took the car out today it seems slightly better - I am getting a couple of idle surges when I stop at a light vs. continual surging.
I think I will need to buy a new one to resolve the problem entirely, but will see if I can last the season as I have spent a bit too much this year already (new shocks, tires, DME Relay, Sensors, oil return lines, etc.) |
| All times are GMT -8. The time now is 11:37 PM. |
