 Hello
	Mr lee is correct. But the difference beetween a standard coil and the Porsche HKZ coil is that the Porsche unit doesn´t have to charge the load ( capazity ), it is only a transformator with makes it more effective and faster. Also the breaker point has only a slight charge to bear and doesn´t need a condensor. The only reason to change it is as the unit will wear mechnical but the contacts will not burn away. Grüsse Maintance tips: http://www.autotruck.net/ms/archives/1998/1298/1298ctp.asp  |
| All times are GMT -8. The time now is 05:00 PM. |
